Systeemupdate Rlink2 naar 3.3.16.960 (was 940) beschikbaar
Topic author - lid
- Posts in topic: 8
Las net het bericht op GPS-Rlink.com dat voor de Rlink2 met 3.3-syteem er een systeemupdate beschikbaar is. Van 3.3.16.940 naar 3.3.16.960. Leek me wel een apart topic waard om niet de verwarring te hebben met map-updates.
En, het is een interessante want er zitten updates in voor Bluetooth-compatibiliteit, bugfixes voor meer stabiliteit van het systeem en patches voor de navigatie.
https://www.gps-rlink.com/2018/11/15/r- ... /#more-933
De tekst:
This is a good time for Renault and the updates. After the deluge of map updates (even if it’s not finished), here’s a system update for the R-Link 2 that’s available since today.
It is 3.3.16.960, so for the 3.3.x.y branch. This can be downloaded from the easyconnect.renault.com website (before renault-multimedia.com) as well as for the 2.2.19.300 update.
You enter the VIN of your vehicle on this page (serial number starting with VF1 available on the registration form) and the site proposes the update for those who are currently in 3.3.16.940.
Then it is a ZIP to decompress and put directly on a USB key in FAT 32 (not in a folder). Inserting the key into the vehicle will cause a pop-up to appear offering to install the update. Of course, like all updates, it is made with the engine on. This should be fast: less than 10 minutes.
We notice that Renault has improved its download page by putting all the update process.
For this one we have patches for maps, Bluetooth compatibility and finally the correction of bugs contributing to the stability of the system.
If you are in 3.3.15.41x, normally no update will be proposed, a workshop visit will be necessary to switch to 3.3.16.64x.
De tekst:
Topic author - lid
- Posts in topic: 8
Re: Systeemupdate Rlink2 naar 3.3.16.960 (was 940) beschikbaar
Even de VIN van mijn Mégane IV GT er in gegooid, en jep beschikbaar. Vanmiddag maar eens downloaden en installeren.
Topic author - lid
- Posts in topic: 8
De Nederlandse pagina om je VIN te laten controleren op nieuwe updates:
https://easyconnect.renault.nl/software-upgrade/r-link2
Voor mijn 2.2.19.300 nog geen updates beschikbaar... Het zal toch niet....
Ben benieuwd of deze update eindelijk eens significante verbeteringen gaat brengen!
- Lid - en hoppa, logo 2
Waarom komt deze eigenlijk niet beschikbaar via de RLink Store? Ik heb in ieder geval op de USB stick gezet, straks maar eens installeren. Ik zag niets over de veranderingen op de website. Het enige dat ik hoop dat is opgelost is het hoge aantal disconnects van mijn telefoon via Bluetooth.
Talisman Estate 110 EDC Intense - Beige Dune - 8.7" Bose - Pack Winter Intense - Easy Life Pack - Pack Cruising
Bij mij is het overigens versie .961 geworden. Verschil? Ook verschillende sticks moeten gebruiken en files in map en niet in map voordat hij installeerde. Ben benieuwd wat verschil is...
Ik heb vandaag ook de update gedaan. Bij mij heeft hij trouwens . 966 aan. Ook nog niet meteen kunnen merken wat er anders is maar met een bestand van meer dan 600mb moet er toch iets aangepast zijn.
Ik heb wel redelijk veel last van geen netwerkverbinding. Die melding kreeg ik via coyote maar ook het weerbericht kon niet updaten. De rlink resetten of de auto afsluiten en opnieuw opstarten zorgde dat het weer ging. Hopelijk is dit nu beter met deze update.
Renault grand scenic initiale paris Gris Cassiopée met zwart dak Tce 160 Edc full option + glazen panoramisch dak
Ook maar even een test gedaan of er voor mijn 2.2.300 versie een update is, maar nee hoor...... Wij worden weer "vergeten"
(ex) bezitter van een Mégane 1.5 dCi Bose uit 2016, Kleur: Rouge Flamme, Easy Life Pack, 8,7 inch R-Link 2
Gr. Cor
Zonder (auto)transport staat alles stil
www.beroepschauffeurs.com
Gr. Cor
Ik vermoed dat deze nog wel verschijnt hoor. Ze kunnen het echt niet maken om de kopers van het 1e uur in de kou te laten staan. Alhoewel.. het zou mij eigenlijk ook niet verbazen...
Hoezo vergeten, volgens mij is dit pas de eerste update voor de 3 versie sinds anderhalf jaar, de 2 versie heeft het afgelopen jaar al diverse updates gehad.
Ik had eerder het gevoel dat de 3 versie vergeten zou worden
Clio V E-Tech Hybrid Alpine (vanaf 27-01-2024)
Easylink versie: 283C37565R (sinds 27-01-2024)
Kaartversie: 2024v1
Clio V E-Tech Hybrid Série Limitée (t/m 01-2024)
Clio V R.S. Line TCE 130 (12-2019 t/m 05-2021)
Ik ben sinds een maand of 3 in het bezit van een Renault Megane.Dat bevalt mij prima.
Vorige week heb ik de navigatiekaarten geüpdatet naar V2017-12 en vandaag de software voor de RLink2 naar 3.3.16.966.
E.e.a. verliep zonder problemen.
Wat mij tot nu toe opgevallen is aan de nieuwe RLink2-software is dat de snelheidsborden niet meer in het instrumentenpaneel verschijnen.Alleen nog maar op de navigatiekaart.Bij de vorige versie van de RLink2 was dat nog wel het geval.
Kan het zijn dat ik ergens een instelling gemist heb of is deze optie gewoon verdwenen ?
Renault Megane IV Energy TCE 130 BOSE, Blue Cosmos,Aug2018-Febr2022
Renault Capture II Intens Tce 140 Edc, Blanc Nacre, Febr2022-
Ik heb nog niets nieuws tegengekomen met de nieuwe update maar kan u alvast zeggen dat bij mij na de update. 966 de verkeersborden nog steeds verschijnen op het instrumentenpaneel en de hud-display. Het zal dus wel ergens een instelling zijn die je zal moeten aanpassen.
Bij mij na de update naar 3.3.16.961 is alleen de zoomfactor van de kaart in het overzichtsscherm (kaart en media naast elkaar) aangepast, iets verder ingezoomd zodat alle straten weer zichtbaar zijn. Overige aanpassingen zitten waarschijnlijk onder de motorkap van het RLINK programma
Een Austral techno 200 in gebruik, eerste ervaring positief
Topic author - lid
- Posts in topic: 8
Had ik ook vreemd genoeg. Even naar Menu -> Voertuig -> Hulpsystemen. Daar vind je iets met snelheidsweergave / waarschuwing. Die moet op aan staan.Fremer schreef: Wat mij tot nu toe opgevallen is aan de nieuwe RLink2-software is dat de snelheidsborden niet meer in het instrumentenpaneel verschijnen.Alleen nog maar op de navigatiekaart.Bij de vorige versie van de RLink2 was dat nog wel het geval.
Ik heb net toch even gebeld met RN over de 2.2 update. Maar wat is dit toch elke keer een sneue bedoeling zeg. Niemand weet er iets, er worden bullshit teksten voorgelezen, inhoudelijk is de kennis een lachertje.
Kortom ze wist niks mbt tot een software update voor de 2.2 gebruikers...
Ik heb vandaag alvast 1 verandering ontdekt met de nieuwe update. Helaas geen leuke. Al mijn favorieten adressen waren spoorloos. Dus dat wordt alles opnieuw ingeven pfff
Het wissen van de adreslijst en favorieten stond er bij de installatie als waarschuwing ⚠ bij, was dus voor mij geen verrassing.
Topic author - lid
- Posts in topic: 8
Klopt, die is er niet. Nog nietKnippie schreef: Kortom ze wist niks mbt tot een software update voor de 2.2 gebruikers...
Ik weet dat die update er niet is. Maar ik mag van Renault toch wel verwachten dat zij kunnen aangeven wanneer die release gepland staat, welke inhoudelijke issues zijn aangepast/ opgelost, kortom wat gaan wij merken van de update.. Niks van dit alles. Vind ik bar slecht
Op het Duitse forum het volgende gevonden betreffende de aanpassingen
Hallo samen: antwoorden van Renault, wat zijn de veranderingen van versie 3.3.16.946 naar 3.3.16.96x precies?
Hier is het antwoord: Bedankt voor uw aanvraag betreffende de systeemversie 3.3.16.96x voor het R-Link 2-systeem.
Volgens de informatie die voor ons beschikbaar is, zijn de volgende functies verbeterd met de nieuwe firmware:
- Bevriezing van het R-Link-display is geëlimineerd.
- Bluetooth-protocollen zijn bijgewerkt.
- Carplay start automatisch.
- Starttijd van het systeem.
- Foutmelding tijdens installatie van de kaart zal worden geëlimineerd.
- Adresinvoer met de spraakfunctie nu mogelijk.
Voor verdere vragen en suggesties staan wij tot uw beschikking.
Groet Urs
Groet Urs
Wie zegt dat er een update komt voor het versie 2.2...….?Knippie schreef:Ik weet dat die update er niet is. Maar ik mag van Renault toch wel verwachten dat zij kunnen aangeven wanneer die release gepland staat, welke inhoudelijke issues zijn aangepast/ opgelost, kortom wat gaan wij merken van de update.. Niks van dit alles. Vind ik bar slecht
Zijn bovenstaande punten al niet eerder dit jaar opgelost in meerdere updates voor versie 2.2....?LeoGroen schreef:Op het Duitse forum het volgende gevonden betreffende de aanpassingen
Voor versie 3.3.... was dit de eerste update sinds ruim anderhalf jaar, misschien liep versie 3.3.... wel achter?
Kaartversie: 2024v1
Tja, als ik dit zo lees dan lijkt het er wel op. Maar mijn punt is dat RN dus ook kan zeggen: er komt geen update voor 2.2. Das ook een antwoord he.
Hallo Adinssx,adinsx schreef:Had ik ook vreemd genoeg. Even naar Menu -> Voertuig -> Hulpsystemen. Daar vind je iets met snelheidsweergave / waarschuwing. Die moet op aan staan.Fremer schreef: Wat mij tot nu toe opgevallen is aan de nieuwe RLink2-software is dat de snelheidsborden niet meer in het instrumentenpaneel verschijnen.Alleen nog maar op de navigatiekaart.Bij de vorige versie van de RLink2 was dat nog wel het geval.
Bedankt voor je tip.Snelheidsbord in instrumentenpaneel is weer terug.
Topic author - lid
- Posts in topic: 8
M.b.t. die update-punten.
Carplay start nu inderdaad automatisch. Enerzijds fijn, maar wel even wennen. Was gewend de telefoon aan te koppelen en gewoon verder te gaan met adres instellen. Nu moet ik eerst weer even carplay wegklikken.
Adres invoeren met stembesturing kon ik dan weer altijd al. Zat dus al in 940 denk ik.
Ik vind Rlink vooral weer wat vlotter geworden, maar dat kan ook bedrog zijn natuurlijk.
Had de 3.3.16.961 al geïnstalleerd en nu geeft het systeem in de auto aan dat er een update beschikbaar is en, jawel hoor, een update naar 960 is beschikbaar. Ik heb hem gedownload, maar is dit niet een down-date i.p.v. een update? Doen of toch maar niet?
Ik heb even gekeken en zie ook dat er een update is. Van versie 966 in mijn geval ook terug naar 960. Ik heb die Gedownload om eens te kijken naar de bestanden die in de zipfile staan en deze zijn aangemaakt in september 2017. Dus dat is effectief terug naar de oude update? Misschien zijn er problemen opgedoken met de nieuwe update en kan je op die manier terugkeren? Ik heb voorlopig geen problemen dus laat die gewoon op de 966 staan voorlopig.
Topic author - lid
- Posts in topic: 8
Jep, ik kreeg vanavond in de auto ook die melding. Heb nog niet gekeken naar welke versie ik kan updaten, of misschien wel downgraden als ik jullie posts zo zie.
Zal eens kijken of er meer info over te vinden is.
Ik wacht dan ook nog maar even met deze downgrade..... Zie overigens wel dat de inhoud van de zips precies hetzelfde is. Zelfde bestanden, precies dezelfde grootte en zelfde datum.
Ik probeer nog steeds de locatie te vinden waar die cryptische zin "Ga naar om uw gratis update te downloaden. Goede reis!" naar verwijst...
Ik snap best dat Renault een Frans bedrijf is, maar met behulp van een projectteam van Renault Nederland, met de hulp van een aantal externe consultants, had het toch best mogelijk moeten zijn om een keurige volzin in correct Nederlands te sturen?
Jij verwacht wel weer HEEL VEEL van Renault
Gr. Cor
Gr. Cor
Ik heb de ‘downgrade’ geprobeerd, maar kreeg de melding:
Het is niet mogelijk een eerdere softwareversie te installeren. Huidige software is behouden.
Heel bijzonder dat er dus een ‘update’ klaar staat.
Kadjar Energy TCe 130 Bose voorzien van Pack Winter en Pack Technology
Bedankt voor de info, dan gaan we het maar niet proberen. Gek dat je nergens verdere informatie hierover kan vinden.
Mensen, vraagje...
Is de update dmv USB uit voeren tijdens het rijden? Of moet ik letterlijk 10 minuten (of langer) met draaiende motor ergens stil gaan staan om de update voor elkaar te krijgen?
2018 Grand Scenic Bose EDC 1.5Dci [Kleur: Blauw/Zwart 2-tone]
Topic author - lid
- Posts in topic: 8
Ik vind het altijd een mooie gelegenheid om een lekker blokje rond te gaan sturen met de GT .bvstrien schreef:Mensen, vraagje...
Dus nee, niet stil staan, gewoon lekker rijden. Radio-volume kun je op zich wel bedienen, verder niet teveel vergen van Rlink tijdens het proces
Thanx! Helemaal gepiept inmiddels tijdens het rijden....in 4 minuten zelfs! Wauw....het moet niet gekker wordenadinsx schreef:Ik vind het altijd een mooie gelegenheid om een lekker blokje rond te gaan sturen met de GT .bvstrien schreef:Mensen, vraagje...
overigens ook versie 966 voor mij...
- 949 Weergaves
Laatste bericht door renjordi
- 159 Weergaves
Laatste bericht door Hawkeye123
- 150 Weergaves
- 702 Weergaves
Laatste bericht door Marcello
- 19 Reacties
- 1581 Weergaves
Laatste bericht door Leo1959
- 984 Weergaves
Laatste bericht door jpvw
- 119 Weergaves
Laatste bericht door EspaceVI_driver
