Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
- Posts in topic: 6
- Laatste bezoek: 01 dec 2019 15:01
hello. I'm writing from portugal because I also have a problem with a Renault Laguna 2 2007 cabasse problem. I have no audio and the cd changer is dead with ignition on. with ignition of I can eject and load cd's but still no sound. does anyone know what is the problem usually?
- Posts in topic: 7
- Laatste bezoek: 02 jun 2025 13:24
Re: Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
Did you check all fuses? One for the radio/navigation in the usual fuse-compartment and one 20A fuse behind/under the ashtray.
- Posts in topic: 6
yes. they are OK
a video showing the problem:
- Posts in topic: 6
no one can help me?
- Posts in topic: 7
I have a lot of experience with these Cabasse systems, also with repairs. But after reading your story and watching the movie, I still have no glue what is really the problem.
So please try to describe as clear as possible when the system is working and when not. Common problem is a faulty amplifier. No sound at all with some little sound when playing CD's.
- Posts in topic: 6
Ok...
Sound: when switching the ignition on I get static no Mather the frequency. Then, with variable timing, I get a POP and the sound goes completely off. The amplifier was changed and it's the same. Faulty replacement part?
Radio usage:
Ignition ON: can use without any problem the satellite control, near the stearing. Can't select cd's. CD changer Dead. Even the power button doesn't work neither lights.
Ignition off: can start the radio with power button on the cd changer. Can eject cds and load the last ejected cd.
Still no sound neither lights.
Radio usage:
- Posts in topic: 7
The popping sound for sure is caused by the amplifier. The strange part is that both amplifiers have exactly the same behavior.
Normally the popping sound does not cause the dead changer when the ignition is on. But the changer is connected to the amplifier, so, if there is a problem with the amplifier, it might be possible that your fault description is caused by that amplifier.
Faulty amplifiers are not extremely rare, so the chance that a replacement amplifier is also faulty, is possible.
- Posts in topic: 6
ok. I'll try to change the amplifier and try to check for dry solders, especially those two power regulators
- Posts in topic: 7
Repair of these amplifiers is not that easy without proper experience. You easily destroy more than you can solve!
- Posts in topic: 6
I'll have it serviced by an electronic repair shop... any thing that I should say to them to be careful?
- Posts in topic: 7
Most repair shops do a trick, without really fixing the several issues which can occur with these amplifiers. After several years of repair experience, together with a full test network for this system, I can assure you that an amplifier is really OK after I have checked it!
- repeating visitor
- Laatste bezoek: 14 dec 2020 20:44
Ik heb hetzelfde probleem Rich ,zou jij kunnen helpen?Ben anders bang dat dit een duur geintje wordt. Heb begrepen dat jij al enige jaartjes ermee bezig bent.
- Posts in topic: 7
[mention]stannie1971[/mention]: dat klopt, al iets van 8 jaar of zo
Wat zijn exact de klachten dan?
- 2-hit-miracle
- Laatste bezoek: 03 aug 2024 21:20
Ik heb nu net een Laguna gekocht met zelfde probleem repareer jij deze dingen nog? Zo ja dan wil ik graag even contacten met je. Als dat mogelijk is.
- Posts in topic: 7
Ik repareer deze systemen nog steeds. Dus je kan mij contacteren.
- 2-hit-miracle
Hoe kan ik je contacteren via mail of whatsapp?
- 365 Weergaves
Laatste bericht door CakeyEV
- 13 Reacties
- 1075 Weergaves
- 8 Reacties
- 595 Weergaves
- 211 Weergaves
Laatste bericht door Jan van Egmond
- 246 Weergaves
- 199 Weergaves
Laatste bericht door OriginX
- 605 Weergaves
