Hi Simone. Heb je in de Settings het device "Konnwei OBDII" of iets dergelijks gekozen ? Anders doet Canze het niet. Als je op "Device" klikt, zie je een lijstje met Remote Devices.
Zie
https://canze.fisch.lu/qa/
Q: I bought a KW902 as you advised. The power light comes on and that’s it?
A: You probably did not pair your device. Here is what you do:
– plug in the KW902 and make sure it is switched on;
– on the Android device open the Settings app and choose Bluetooth;
– you see the Bluetooth screen. Make sure Bluetooth is on;
– the screen shows any devices already paired with the tablet. Also shown are other Bluetooth devices available for pairing;
– the KONNWEI OBDII should appear. If it doesn’t, touch the Search for Devices button;
– choose the KONNWEI OBDII device from the list;
– If necessary, type the device’s passcode (1234) or otherwise acknowledge the connection.
Now you can start CanZE and don’t forget to choose the proper device in the settings screen.
Renault Zoe Zen, blanc nagre. Q210 sinds December 2014. KM > 110k. Frank & Anja. +Zero SR/S (8-2020)
Website: Mostaladda.eu voor EV apps. Op weg geweest naar: Luxembourg (L), Bremerhaven (D), Orleans/Chambord (FR), Bern/Luzern (CH)/Liechtenstein, Rügen (D), Klausen (IT), Landau i.d.Pfalz (D)
