Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
manel
Topic author - Op weg
hello. I'm writing from portugal because I also have a problem with a Renault Laguna 2 2007 cabasse problem. I have no audio and the cd changer is dead with ignition on. with ignition of I can eject and load cd's but still no sound. does anyone know what is the problem usually?
Re: Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
Did you check all fuses? One for the radio/navigation in the usual fuse-compartment and one 20A fuse behind/under the ashtray.
manel
yes. they are OK
a video showing the problem:
manel
no one can help me?
I have a lot of experience with these Cabasse systems, also with repairs. But after reading your story and watching the movie, I still have no glue what is really the problem.
So please try to describe as clear as possible when the system is working and when not. Common problem is a faulty amplifier. No sound at all with some little sound when playing CD's.
manel
Ok...
Sound: when switching the ignition on I get static no Mather the frequency. Then, with variable timing, I get a POP and the sound goes completely off. The amplifier was changed and it's the same. Faulty replacement part?
Radio usage:
Ignition ON: can use without any problem the satellite control, near the stearing. Can't select cd's. CD changer Dead. Even the power button doesn't work neither lights.
Ignition off: can start the radio with power button on the cd changer. Can eject cds and load the last ejected cd.
Still no sound neither lights.
Radio usage:
The popping sound for sure is caused by the amplifier. The strange part is that both amplifiers have exactly the same behavior.
Normally the popping sound does not cause the dead changer when the ignition is on. But the changer is connected to the amplifier, so, if there is a problem with the amplifier, it might be possible that your fault description is caused by that amplifier.
Faulty amplifiers are not extremely rare, so the chance that a replacement amplifier is also faulty, is possible.
manel
ok. I'll try to change the amplifier and try to check for dry solders, especially those two power regulators
Repair of these amplifiers is not that easy without proper experience. You easily destroy more than you can solve!
manel
I'll have it serviced by an electronic repair shop... any thing that I should say to them to be careful?
Most repair shops do a trick, without really fixing the several issues which can occur with these amplifiers. After several years of repair experience, together with a full test network for this system, I can assure you that an amplifier is really OK after I have checked it!
stannie1971
- Op weg
Ik heb hetzelfde probleem Rich ,zou jij kunnen helpen?Ben anders bang dat dit een duur geintje wordt. Heb begrepen dat jij al enige jaartjes ermee bezig bent.
[mention]stannie1971[/mention]: dat klopt, al iets van 8 jaar of zo
Wat zijn exact de klachten dan?
Peter1970
RichTrip schreef: 09 nov 2020 09:10 @stannie1971: dat klopt, al iets van 8 jaar of zoWat zijn exact de klachten dan?
Ik heb nu net een Laguna gekocht met zelfde probleem repareer jij deze dingen nog? Zo ja dan wil ik graag even contacten met je. Als dat mogelijk is.
Ik repareer deze systemen nog steeds. Dus je kan mij contacteren.
Peter1970
Hoe kan ik je contacteren via mail of whatsapp?
Weergaves: 625 -
Laatste bericht door Pleiades
28 jul 2026 17:33
Renault Laguna 2 2007 automatische handrem komt na het starten in geen mogelijkheid meer los
door Vertrokken gebruiker 42732 » 11 dec 2023 15:54 » in Technische vragen Laguna -
Weergaves: 2410 -
Laatste bericht door Vertrokken gebruiker 42732
25 jan 2024 15:15
Hoe werk start stop systeem bij een Renault Laguna ll fase uit 2007 is een business uitvoering
door steefd82 » 10 jan 2024 03:20 » in Technische vragen Laguna -
Weergaves: 1484 -
Laatste bericht door steefd82
11 jan 2024 18:35
Weergaves: 1042 -
02 mar 2024 08:15
Weergaves: 1215 -
20 apr 2024 13:19
Reacties: 8
Weergaves: 2212 -
31 jan 2025 08:03
Weergaves: 1039 -
Laatste bericht door Jan van Egmond
27 jan 2025 14:19
