[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1479: Undefined array key "user_topics" [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1820: Undefined array key 3081 [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1820: Trying to access array offset on value of type null [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1820: Undefined array key 3081 [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1820: Trying to access array offset on value of type null Renault Radio Code opvragen - Pagina 39 - RENAULT-forum
Model/uitvoering :renault megane II Bouwjaar :2003 Brandstof :DIESEL
hallo iedereen
ik had gisteren mijn lichten vergeten uit te zetten wat bleek batterij plat nu na het starten geeft de autoradio code invoeren? deze code heb ik niet heb wel de radio eruit gehaald
MODEL NO :22DC277/62
T0E029
RN277F30246772
PROD NO:: FD0103290246772
8200256141TE029
hopelijk kan iemand me helpen met de code
Laatst gewijzigd door Gast op 03 dec 2013 12:49, 1 keer totaal gewijzigd.
Reden:Caps lock uitzetten aub
Heeft iemand misschien de radio code voor mij. De kabelboom en weerstand van mijn verwarming waren vervangen en toen was de stroom eraf. En ik had helaas geen radio code.
Gegevens van de radio:
@Rajesh: De code word uitgerekend aan de hand van het serienummer van de radio.
Met het serienummer dat jij gaf klopt deze code.
Kan het zijn dat je het serienummer verkeerd hebt overgenomen?
(het gaat om het lange nummer dat begint met 8200)
Renaults tot nu toe:
- Nevada 1992 Manager (helaas overleden)
- Megane II ph2 2006 business
- Megane III 12-2013 bose
Het verhaal zit zo de garage die mijn verwarming had gemaakt zei dat hij een foto van mijn radiogegevens had genomen.
Deze foto had ik van hem gekregen dus ik ging ervanuit dat het goed was.
Ik heb nu zelf de radio los gehaald en zag tot mijn grote verbazing dat het hele andere nummer waren!!
Hallo Iedereen,
ik heb een renault safrane 2.5 en heb de batterij onlangs moeten vervangen, nu heb ik de code van mijn alpine radio niet meer, kan iemand mij daar mee helpen.
het serie nr. is 77 00 413 127 AAL 96 35 14444 of CM7RN410 01
Ook ik heb een probleem met de radio accu is er af geweest en heb geen code het is een renault megane break uit 2000
gegevens radio model; 22dc259/62t
tom126 rn259fy0040278 profdo200040040278 7700434422tn126
7700434422
Ik hoop dat u hier wat aan heeft en een code vind by voorbaat dank
groet Toon
7700434422tn126 is dus precode n126.
Daar hoort de code 2899 bij voor zover ik nu even kan zien.
Net als hiervoor: weet je zeker dat dit de juiste codes zijn van de radio?
Wie kan mij helpen met de radiocode van mijn Renault?
Na reparatie vraagt hij om een CODE.
De radio eruit gehaald om de sticker te zien met codes:
Volgens mij gaat het om een letter met 3 cijfers erachter? Dit is: 7700434425 TO 051.
Is dit voldoende? Graag hoor ik het, rij al een maand zonder radio....
Wij hebben onze zoe een ohdb laten geven. Nou meer het laten afvinken van een checklist eigenlijk 🤔 maar goed. Gelijk gevraagd of ze de soh willen checken. Dit moesten zij opvragen?? Dit is al een paar weken geleden en elke keer zeggen ze we bellen...
Sinds vrijdag hebben we een scenic uit 2004, hierbij werkt het scherm van de radio niet. (Nog opzoek naar een betaalbaar scherm.). Echter vraagt de radio nu om een code, bij aanstaan hoor je tussendoor een piep en op een gegeven moment gaat de radio...
Standaard ontgrendel je de Megane E-tech met de sleutel of sleutelkaart. De startknop indrukken en gaan.
Is er ook een instelling dat je na het ontgrendelen eerst een PIN code moet invoeren voordat je de startknop kan gebruiken?
Hallo, ik heb een Renault Espace, Initiale Paris uitvoering, uit 2017.
Voor het on-line bestellen van onderdelen moet ik de model code invullen. Ik kan kiezen uit: jra4 jra5 jral jram jrm1 jrme. Weet iemand welk model bij welke code hoort?
Ik ben op zoek naar de motorcode van mijn renault kangoo express 1.5 dci 75 bouwjaar 18-01-2017.
Dit ivm wanneer ik de distributie moet vervangen, bij welke kilometer stand.
Waar kan ik de motorcode vinden?
Alvast bedankt voor jullie...
Dag vrienden!
Ik heb vandaag mijn buurman geholpen met zijn Renault Kadjar die niet goed loopt, en de code scanner (goedkoop Chinees ding) gaf een code voor de nokkenas sensor. Die heb ik nu vervangen en start nu ook al beter, maar krijg nog steeds...
Na een reset van mijn instellingen in de auto is hij niet meer gesynchroniseerd met de app. Als ik hem probeer weer te synchroniseren zou je een code op het display moeten zien, maar ik zie niets, ook niet na 10 minuten wachten. De app geeft aan dat...
